LIMITS (what you can't do with it)
This project is not intended for deployment: use it for prototyping, learning, or just for fun. Do not use it to flash the ESP-01, rearranging the jumpers. For all such uses, the trick of using the capacitor to boost the Arduino 3.3V output is not enough. Instead, use a separate regulator for the ESP.
Augusto Ciuffoletti
kerimil
