The smoothieboard 5X lives
A project log for 3D printer brain retrofit
Breathing new life into a Stratasys Dimension 768 with a Smoothieboard 5X
machinistmachinist • 05/12/2016 at 00:10•0 Comments
Protip - don't use Notepad ++ to edit the config file. CRLF is not LF.
everything else works pretty nicely, interfacing to the Smoothieboard using Pronterface and ReplicatorG. G code created here
