Stouter Brackets
A project log for BuckyBot
A Mobile 3D printer to build Megastructures
ranarchyRanarchy 09/01/2014 at 22:510 Comments
Switched to 0.050" aluminum and the woes go away.  3 brackets usable out of 3 tries... widened the metal surrounding the servo holes and got a small sheet of of 18 ga from OnlineMetals.  The scroll saw sill cuts it, and you can bend it up without breaking it.  Now I can finish the spyder and get to the extruder...
