Choosing a microcontroller for the project (2)
A project log for Guri: Ignition Controller for Air Cooled Engines
Ignition controller for VW air cooled engines.
danjovicdanjovic 04/12/2016 at 21:010 Comments
After comparing some characteristics of the chips, I've decided to stay with the AVR because of the output compare modules, which are convenient for this use but are not present on the PIC.
Also the PIC prescaler for the 16bit module might not be enough for the 8Mhz clock.
