Will not run on emulator!
Written for XC8 v1.20. I use MPLAB8 so haven't included project file -
just create a project, add the 2 source files, and set the code offset to 0x1820
Functions :
At powerup/reset, shows greyscale for a while then goes to ball effect
4 buttons select one of 4 effects :
L - slow-changing ball-griddy thing
T - soft of 'Conway life' type thing - pixel brightness grows or fades depending on density of neighbours
R -falling drops
B - Bouncy 3d-ish ball
Int - on/off (I've not tested power draw when off- _should_ be OK, but someone please check!)
