Hackaday.io Hackaday.io
Sign up Log in
omni wheel mobile robot
A plattform to experiment with an omnidirectional drive
malte-ahlersMalte Ahlers
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.3k views
2 comments
1.7k followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
1.3k
2
1.7k
17
Team (1)
  • malte-ahlersMalte Ahlers
Join this project's team
  • The project on my homepage
Robotics ROBOT omni wheel omnidirectional drive
This project was created on 05/06/2014 and last updated 8 years ago.
Description
I built this robot to gain some experience with the control of a robot with an omnidrectional drive. The omni wheels are cheap ones I bought on ebay. The are driven by three stepper motors with gear boxes. Each stepper has a A4983 driver, the drivers are controlled by an AVR m168. The robot is connected to a PC via RS232.
Details
Components
  • 3 × omni directional wheels
  • 3 × stepper motors with gear boxes
  • 1 × A4983 stepper driver boards
  • 1 × Atmel AVR m168
  • 1 × MAX232 Non-IC RF, IF, RFID, ZigBee Components / Up-Down Converters
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
KaiserKC wrote 05/08/2014 at 17:13 • point
Implementation question:
I discussed this with friends once and wasn't sold on the answer. In your opinion, with your triangular wheel placement, in order to drive in a direction parallel with wheel A at speed x, should wheels B and C each be powered to drive at speed x or should B and C each be powered at speed y, where y would be the value representing the sides of the isosceles triangle formed by wheels B and C (the line connecting B and C being the base of the triangle) and x is the height of said triangle? If this makes no sense then i may be able to produce a picture.
Tonkabot wrote 01/22/2015 at 15:47 • point
From memory, if you want to go in direction A at speed x, then wheels B and C should go at .707x . (that's (1/sqrt(2)) *x)
Here is my robot that has been resting for a few too many years now...
A robot vacuum made with Arduino and MDF
Project Owner Contributor
DIY Robot Vacuum
mr-cookieMr. Cookie
this is a 6DOF robot arm made with steppers motors
Robot Arm ACURA
alexisAlexis
Made this useless robot from junk
From The Junk
tinandjartinandjar
A desktop quadrupedal biomimetic robot with eight degrees of freedom.
There is a desktop quadrupedal biomimetic robot.
geekrosGEEKROS
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "omni wheel mobile robot", please tell us the reason.
Send message
Remove Member
