Coil-O-Mat
A project log for RC Solar Boat With E.M.P. Drive.
E.M.P. drive – Electro Mechanical Propulsion drive.
alain-mauerAlain Mauer 04/12/2018 at 12:120 Comments
Now, I have the Magnets, let us wrap the coils. I will use painted copper wire with a diameter of 0.09mm.
Both of the coils should have 40 Ohm at the end, which makes a lot of wrapping.
So I decided to build me this Coil-O-Mat to make me this task easyer
Hopefully I will finished this quickly, so I can start to do the first tests with the e.m.p.
