Hand-grip and Trigger
A project log for CO2 Cartridge Rocket Launcher
CO2 canister powered rocket launcher, because why not
alex-andersonAlex Anderson 04/10/2016 at 21:140 Comments
Just a brief update; the shearing mechanism is pretty much done and the next step is the hand grip and trigger. The trigger, when pulled, will pull the "firing pin" allowing the shearing plate to move. The trigger will be aluminum with a laser cut hand grip. The trigger will have a spring return, but that is where things get a little complicated, but that is what I need to figure out next.
