New Firmware
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
Tom MeehanTom Meehan 10/13/2016 at 06:060 Comments
Due to code not working consistently - I'm re-writing and simplifying my code to meet my objectives and leaving other unnecessary functions out for now. I need to go back to basics and make the code simpler and more straightforward.
One main area, that I found, that made the code freeze up at times was the strip sensing method - which I have redesigned with an easy to implement hardware and coding solution that should work for all types of strips.
I'll post the essentials to later today.
