HD44780 LCD Display working
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan 06/27/2016 at 08:130 Comments
It took a bit of testing and research but I finally got an HD44780 controller, 16x2 LCD display functioning with the PIC 16F877A, now I need to get it to function with the PIC16F1786 (my target chip). The C-code from Microchip demonstrating a glucometer design used a harder to source 16x2 LCD display, I would have started with that but couldn't get it it. So, I decided to work with a more standard 16x2 LCD. My ultimate goal is to use a Nokia 5110 LCD since it is a bit more compact and fairly inexpensive and easy to source.
I've bread boarded an HD44780 16x2 LCD, connected to the PIC16F1786. I'm currently editing code to test out the LCD.
