Software Flowchart
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan 07/11/2016 at 04:210 Comments
This is my initial Flow Chart for how I want the meter to function. I'm still working out a number of details:
Continuing work on software development (at present this is my biggest challenge, this is my first attempt at using PIC microcontrollers - which require a lot of digging through details in datasheets - in comparison the hardware design is fairly easy) as well as deconstructing commercial strips to determine layouts of contacts and configuration of test strips.
