1st Strip Breakdown "Accucheck"
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan 07/11/2016 at 05:300 Comments
I was able to peel the layers apart on this strip fairly easily (no chemicals, just a razor blade to start)
Sample area:
Contact area:
Here it is after peeling layers off:
Sample area:
Contact area:
This is what I believe the circuit is:
Corrections are below the picture
**Sense electrodes are actually the Working and Counter Electrodes**
**Reaction electrodes are actually the Fill Detection Electrodes.**
Oops - my marked up version of the contact area is gone. Well, suffice to say this strip seems to be designed to used to electrodes - 1 active and 1 reference. There are 2 more electrodes for sensing when blood is applied to the strip. There are 8 contacts at the base of the strip, each of the 4 electrodes branches into 2 contacts. I'm not certain of the function of the serpentine route of the sense electrode on the right (it also has a solid straight track to the left of it) - I have some ideas but I'll need to test further.
To help make the process of strip dissection easier (I've been using an inexpensive low power binocular microscope) I decided to hack together a video microscope. I looked at some projects involving USB camera but decided that I liked the idea of a composite security camera board (I've got a few from old projects - I've also got a few USB cameras). Some people complained that USB camera's didn't update in real time.
I cut a small box for the camera board, mounted it in there. Added an acrylic piece to the top of the box, with a 1/2" hole drilled through it, to accept a 1/2" rod. Lenses I took from optics I've saved from camcorders (other projects), and an old lcd screen pulled from a portable DVD player. In the end I came up with this:
It's not pretty (right now) but it achieves fairly good magnification and should make it much easier to look at strips.
