Temporary Universal Strip Port
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan 07/21/2016 at 04:200 Comments
I went through a number of design ideas for a strip connector, to allow for multiple contact positions. For initial testing I decided to use a test strip connector that I desoldered from a Accu-Check Aviva meter. Since this connector has a total of 8 contacts (spaced 1mm apart). You can see this connector below:
I was able to mount this connector to some perf board and solder the connections to regular (0.25" pitch) male headers. Now it connects perfectly to my solderless bread board.
The number of contacts on test strips varies a bit but most strips now have
Some of these contacts are combined.
I'm also working on using a Nokia 5100 LCD display, since they are available as salvage from old Nokia cell phones and have a nice form factor for a Glucometer Display.
