Standard Test Solutions for the meter
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan 07/24/2016 at 04:222 Comments
Another, very important, part of this project is developing a method of calibrating the meter to different strip profiles and different lots of the same strip. For a bare minimum, we need 2 known glucose control solutions – so we can determine the slope and intercept of the strips response (linear regression – fairly simple algebra) . We need a bare minimum of 2 points to define a straight line (y=mx+b). I initially believed that this would not be an issue since their must be standard glucose control solutions on the market for calibrating glucose meters. As it turns out this is not true, something that M. Bindhammer figured out a few weeks ago developing his Open Source Arduino Blood Glucose Meter Shield (another 2016 Hackaday Prize entry that is going into the finals).
After a bit of research (journal articles, patents, msds sheets – you can check out my reference post to access them), I found that these control solutions are made up of the same basic components:
Patents and Pharmaceutical compounding trade journals provided lists of both viscosity enhancers and antimicrobials.
Viscosity enhacers (not an exhaustive list) :
Natural Hydrocolloids
Antimicrobials (not an exhaustive list):
The antimicrobials seem a bit tricky since each one is most active within specific pH ranges. If we are mimicking human blood, pH range from 7.35-7.45 (slightly basic), this limits our choice of antimicrobials.
Need to determine the pH of glucose solutions with viscosity enhancers (look at pKa values and also check with pH meter). Look at pH of commercial solutions.
The makeup of a few commercial glucose control solutions:
Suresign Resure Glucose Control Solution
McKesson TRUEcontrol® Control Solution
One Touch Ultra Control Solution
CareSens Glucose Control Solution
These are a few of the only manufacturers that have actually listed ingredients and you can see that only a few of them actually provide any idea of concentrations. Of note, while all control solutions I've looked at state that they are only reliable on a single brand of strip - the formulas for making these solutions are essentially identical in how they are made and the base ingredients used. (Good news for me!!!)
Tom Meehan wrote 07/25/2016 at 14:44 point
Oops, my error.  I was actually thinking linear equation (y=mx+b) not linear regression.  I'll add this correction to my log.
M. Bindhammer wrote 07/25/2016 at 14:07 point
Hi Tom,
If you have only a pair of coordinates, you can't use linear regression. For linear regression you need at least 3. The more the better. I would also not call linear regression 'fairly simple algebra' (https://en.wikipedia.org/wiki/Linear_regression) :)
PS: If you need ONETOUCH Ultra strip connectors, I would be happy to send you a bunch.
