YES - finally uncovered the errors!!!
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan 10/15/2016 at 06:070 Comments
I've been going through my design (schematic's, etc.) and coding (quite literally line by line with datasheets in front of me) all week. Finally, I believe I've found the errors that broke the code - both are a mix of hardware and software.
The first issue, which I found fairly quickly, has to do with test strip sensing - when a strip is inserted. The original code that I was building on relied on using the XXX strips which have a straight contact across the bottom of the strip so that when it is inserted it completes a circuit (basically). I had attempted to adopt that to other strips that do not have that straight contact bar across the bottom.
The second issue concerns pin assignments for Switch 4 and for the ceramic oscillator. Somehow, when I was transferring the circuit design from the PIC16F1786 over to the beefier PIC16F1789, I connected the resonator to the incorrect pins - I connected them to the same port pins that the resonator was connected to on the PIC16F1786 (C0 and C1).
On the PIC16F1789 the external timing crystal or oscillator needs to be connected across A7 and A6 (pins 31 and 37 on the surface mount package I'm using). If that wasn't enough - I attached the digital input for Switch 4 to pin 31 (A7). So, of course I need to change the input pin for Switch 4.
Just to get back to a working prototype, I've changed the code so that the strip sense pin (which has a pullup resistor on it) is attached to a reed switch that when triggered pulls the pin to ground potential. I also switched to the internal oscillator (4MHz) to avoid needing to solder wires directly to the chip.
After it's working correctly, again, I'll implement a simpler variation of a reed switch into the strip reader/contact housing. Also, I'll be posting all these corrections to the schematics and gerbers for the board ASAP.
In addition, I'll be adding 1 more pin to the strip reader connector, to monitor the "Fill" detection electrode.
