DAISEE 0.8 - Building Ethereum Nodes, Smartcontract and DApps
A project log for [2016] InternetS of Energy - Call me DAISEE
Decentralized Autonomous Interconnected Systems for Energy Efficiency - A blockchain based energy DAO
rieul-techerRieul Techer 08/21/2016 at 13:180 Comments
As part of the development of some bricks of the DAISEE program, two of the main technological bricks are:
Documentation can be found here (documentation is still mainly in french, we'll do our best to translate it - if by any chance you wanna help you're more than welcome):
You'll also found more detail instruction on the instruction web page.
Documentation: Ethereum Installation (RaspberryPi) using GETH and an alternative way for the Installation of an Ethereum node on a Raspberry Pi using PARITY
In the related documentation, you'll find the process for the installation of an Ethereum node on a Raspberry PI using various techniques. It also focuses on the problems and difficulties we've been facing and how to overcome some of them.
Please note that the first attempts have been carried out on the emonpi which is a costumed raspberry pi for the Open Energi Monitor. However, the process is further described in the document for Raspberry Pi in general.
3 ethereum nodes on Raspberry PI talking to each other on a common private blockchain
Building a peer-to-peer energy transaction smart-contract
Documentation: Design & Deployment of SmartContrat Peer-to-peer Energy
The first step before building the smart-contract is to define
Why do we need a smartcontract ?
We need a smartcontract in order to automate the energy and currency transaction processes between peers. Indeed, the aim is to make it simple for the prosumer to manage the transactions with other prosumer while keeping the process transparent and appropriable.
What does it need to do ?
For us and at the moment, it need to automate transactions while called automatically by a prosumer either selling or buying energy.
How does is do it and when ?
It does it while comparing on an "energy market" who's producing to much and who needs energy for consumption. Then it triggers the transaction while being called by a prosumer automatically. Finally, it updates the energy and currency account while providing both account with the necessary (positive or negative) balance.
Building a dApp
Documentation: Design & Deployment of DApp
The dApp enables to have a user interface to manage the smartcontract and, thus, the transaction process. The related documentation focuses on the development of decentralized application based on Ehtereum Javascrip API WEB3.
The dApp makes it possible to see :
The accounts are updated each time there is a transaction from a producer to a consumer. Here is a video showing the transaction virtually happening between two accounts:
Conclusion
From now, we are able to :
Our problems :
What's remaining to be done :
Extracted from the BlockChainDB white paper.
