Simple oscillator
A project log for SPDT16: 16-bits arithmetic unit with relays
Let's imagine I could get about 200 SPDT relays. Of course I would know what to do with them :-D But will 200 be enough ?
Yann Guidon / YGDESYann Guidon / YGDES 05/06/2016 at 06:300 Comments
After some trials and errors, I've settled to this system:
3300µF was what I had easy access to, I wanted to make a ring oscillator so I looked for 3 identical high-valued electrolytic capacitors and they looked nice.
I get about 12Hz. The frequency is affected by the series resistor, which I had to reduce in order to keep a stable oscillation because it doesn't start up quiclky.
I initially started with a safe value of 47 Ohms because the coil is 35 Ohms but it didn't work well. It was a bit better at 22 but 10 Ohms keeps oscillating at 4V. The inrush current is in the order of 400mA... (coil dropped below 1V, Vcc=5V, I=(5-1)/10=0.4A)
Maybe I should add a lamp in series to keep it running ?
Anyway, with 10 Ohms, the charging pulse lasts about 10ms, with 65ms of discharge.
That's about 1/75ms=13Hz.
Zooming in the charging pulse, I can see strong ringing...
No wonder my frequency meter was confused !
More action on youtube:
20161107: Oh yeah, the inrush current is 4× the rated 100mA current... No wonder it doesn't work well.
I'm about to make a longer ring oscillator usign PBRL to test the endurance, this will limit the current and check the speed up to 50Hz...
