What are the echomods
A project log for A HSDK for ultrasound imaging
Using a Raspberry-based hardware and software development kit to understand ultrasound imaging
kelu124kelu124 04/26/2016 at 21:540 Comments
The principles of the echOmods is to enable a full chain of ultrasound image processing and hardware control. Four basic modules are considered. Each of this module will be landing on a motherboard, more or less a stripboard.
Key interfaces, signals and alims will be available on each of the 19 tracks on the motherboard, and will enable communication between modules. However, some tracks can be unused by the modules.
In this dense version, there are 4 modules electronic modules, the Transducer and the Motor modules are not depicted.
These modules can have a form factor close to the arduino trinket pro, with a row of 19 pins on the side. Each module will have a function, as described below. At the heart of this project, there will be 4 modules, plus the motherboard. 2 of these modules will be SMD, 2 as modules based on stripboards. Two additional modules will enable replacing the transducer module and getting advanced signal acquisition/streaming, respectively
