Raspberry Pi setup
A project log for A HSDK for ultrasound imaging
Using a Raspberry-based hardware and software development kit to understand ultrasound imaging
kelu124kelu124 05/29/2017 at 19:540 Comments
Here's a tentative setup for the SDK. It's based on a motherboard exposing all interesting signals, a Pi (W in this case), an ADC shield (detailed here) which goes up to 10/11Msps, and the pulser as well as analog processing modules.
Things to do now:
Beware, I had to use a 750mA 5V power supply for the USB power. It does use a tad of power as is!
