More experiments - and a new driver
A project log for A HSDK for ultrasound imaging
Using a Raspberry-based hardware and software development kit to understand ultrasound imaging
kelu124kelu124 10/01/2017 at 14:320 Comments
Working on a new version of the kernel module - here. Also tried a new version of th pulser.. a plastic tube stuck on the transducer. Helps to fix a point at a fixed distance, see below:
The results went well:
Read more about the experiment on the gitbook.
