AVO's WaveGen
An open source, cheap, DIY wave generator for the budding electronics hobbyist
  • The Design Specs
    camerontbelt05/07/2014 at 20:37 0 comments
    The design specs for this project are as follows:
    *Needs to produce at least these three waves: sine, square, and triangle wave forms. saw tooth and pulse would also be good.
    *Frequency needs to be able to easily vary from a few Hz to tens of kiloHz or MegaHz
    *Needs to display and select key information e.g. frequency, offset voltage, amplitude etc.
    *Voltage offset TBD
    *Amplitude adjustment
View project log
Jake wrote 05/08/2014 at 16:53 point
What sort of BOM cost are you aiming for?:) I love tools I don't have to buy!
camerontbelt wrote 05/08/2014 at 16:58 point
right now its sort of vague, its really in the early idea stage. In the picture above i have a max 038 IC but i realized this wouldn't be optimal, my understanding is that the IC isn't really for producing varying frequencies, its more for using components to get one frequency out and thats it. Not to mention its not manufactured anymore.
But to answer your question, the idea i have in mind should be fairly cheap, since its in my head i can only give a rough estimate (and assuming the design in my head works) it should be very cheap. The most expensive thing that comes to mind is the atmel processor for the ardunio uno, and the op amps.
Thanks for your interest, and any more questions or help just let me know!
