Drakkar ready to be tested
A project log for Drakkar - printable robotic prosthetic leg
An open source 3D printable robotic prosthetic leg.
david-sanchez-faleroDavid Sanchez Falero 10/03/2016 at 16:260 Comments
I have developed a new stronger structure to reduce the effects of mechanical deformation produced by the linear actuator.
You can see the difference between the two models in the following images:
