New drakkar assembly guide
10/29/2016 at 11:41 • 0 commentsI just added the assembly instructions for the leg on github.
All information is at the following links:
N7 Anvil assembly
N7 Anvil Knee assembly.
N7 Anvil Leg assembly.
Goat Leg assembly. -
Drakkar ready to be tested
10/03/2016 at 16:26 • 0 commentsI have developed a new stronger structure to reduce the effects of mechanical deformation produced by the linear actuator.
You can see the difference between the two models in the following images:
Madrid Mini Maker Faire 2016
09/27/2016 at 17:37 • 0 commentsI've been giving a talk about Drakkar at the Madrid Mini Maker Faire. [slides]
