NodeLP test
A project log for NodeLP - Low power solution for DIY Sensor
NodeLP is designed for low power sensor node.Use it with any board such as Arduino, ESP8266, CC3200, CC2541 and other WiFi, BLE dev boards.
Michael WenMichael Wen 07/06/2016 at 18:160 Comments
It took a whole month to test the NodeLP, and the results are promising, it more than doubled the run-time of my NodeUSB sensor!
Use NodeLP without change anything for existing setup, I am able to run the WiFi sensor for 30 days using 1500 mAh power bank. All I need to do is plug the NodeLP between the battery and NodeUSB.
6/1/2016, 3:07:57 PM [('s', u'bmp085si7021'), ('t', u'20.87'), ('h', u'53.86'), ('st', u'20.7'), ('ap', u'98353'), ('ip', u'192.168.1.126'), ('v', u'855')]
6/6/2016, 11:58:42 PM [('s', u'bmp085si7021'), ('t', u'15.28'), ('h', u'85.11'), ('st', u'15.1'), ('ap', u'96570'), ('ip', u'192.168.1.126'), ('v', u'826')]
6/10/2016, 8:52:29 AM [('s', u'bmp085si7021'), ('t', u'20.37'), ('h', u'43.79'), ('st', u'20.2'), ('ap', u'98447'), ('ip', u'192.168.1.127'), ('v', u'807')]
6/18/2016, 7:13:20 PM [('s', u'bmp085si7021'), ('t', u'29.63'), ('h', u'32.67'), ('st', u'29.5'), ('ap', u'98791'), ('ip', u'192.168.1.127'), ('v', u'787')]
6/20/2016, 11:20:08 PM [('s', u'bmp085si7021'), ('t', u'22.56'), ('h', u'50.35'), ('st', u'22.4'), ('ap', u'97580'), ('ip', u'192.168.1.127'), ('v', u'780')]
6/22/2016, 9:22:40 AM [('s', u'bmp085si7021'), ('t', u'21.16'), ('h', u'53.41'), ('st', u'21'), ('ap', u'97821'), ('ip', u'192.168.1.127'), ('v', u'778')]
6/25/2016, 6:09:47 PM [('s', u'bmp085si7021'), ('t', u'28.19'), ('h', u'35.39'), ('st', u'28.1'), ('ap', u'98550'), ('ip', u'192.168.1.127'), ('v', u'763')]
6/27/2016, 2:34:54 PM [('s', u'bmp085si7021'), ('t', u'30.35'), ('h', u'44.40'), ('st', u'30.2'), ('ap', u'97707'), ('ip', u'192.168.1.127'), ('v', u'756')]
6/28/2016, 6:17:36 PM [('s', u'bmp085si7021'), ('t', u'20.84'), ('h', u'65.99'), ('st', u'20.7'), ('ap', u'97972'), ('ip', u'192.168.1.127'), ('v', u'750')]
6/29/2016, 4:00:05 PM [('s', u'bmp085si7021'), ('t', u'25.68'), ('h', u'38.99'), ('st', u'25.6'), ('ap', u'98067'), ('ip', u'192.168.1.127'), ('v', u'723')]
6/30/2016, 5:25:04 PM [('s', u'bmp085si7021'), ('t', u'26.63'), ('h', u'34.33'), ('st', u'26.5'), ('ap', u'97978'), ('ip', u'192.168.1.127'), ('v', u'630')]
