Atmega88V BOD and sleep power consumption
A project log for NodeLP - Low power solution for DIY Sensor
NodeLP is designed for low power sensor node.Use it with any board such as Arduino, ESP8266, CC3200, CC2541 and other WiFi, BLE dev boards.
michael-wenMichael Wen 07/09/2016 at 14:290 Comments
After disable BOD in Arduino code, I got much better results:
I used to need 1000 uF capacity, now 100 uF can power Atmega88V for few minutes.
