Problems with 1.0 board
A project log for Raptor12 Wireless AC Dimmer
Christmas, Halloween light string controller that is wireless, 12channel dimmable AC controller, with an AVR for $30
kingofkyatravis-kKingOfKYA(Travis K. ) 07/19/2014 at 20:260 Comments
First thing clearance The top of the fuses of the ac/logic board and the rectified positive voltage can easely be shorted together if the top board is flexed do to the use of a flooded copper region on my top fet driver board. Easy fix for this prototype i just found some scrap pcb and superglued it to the bottom of the fet board.
On this revision i also removed the lower screw holes as there really not needed. Then when adding the second offset nrf footprint i managed to move the 3v regulator to where the original screw hole was. So there was a plastic stud that is now in the way of the voltage regulator. So i had to put the components on the revers side of the board.
I added this jumper to allow for testing of the power supply before  it is connected to the micro and the rest of the board. But on the silkscreen i put it on the wrong side. Oh well another easy fix.
The tiny to-92 transistor that i original specked didn't cut it  with the micro running at full speed it was overheating and failing. So now I have a to-220 transistor in there a tip120. I also had to adjust 2 resistor to setup the biasing correctly for the new transistor that has a higher gain the 2 blue resistors in the pic below. Ignore the flux mess i ran out of the no clean stuff, this stuff is harder to get off.
SO getting there hopefully one more board spin:)
