TCP vs UDP protocol over RF
A project log for Robot Communications Module
Communicate with your robot over long-ranges using a variety of plugins (RF/cellular/laser)
neil-k-sheridanNeil K. Sheridan 04/03/2018 at 20:060 Comments
Can we use TCP over RF? Is there going to be an issue here about overloading the sender with NAK or NACK (negative-acknowledgement [ACK]) signals because we are getting many lost packets/packets out of order/etc.?
I found a white paper on this issue here: http://www.rtlogic.com/~/media/datasheets/whitepapers/rtl-mwp-079_adapting%20rfif%20over%20ip%20within%20range%20applications.pdf
