5.8Ghz: Video transmitters used for FPV in drones, and possible modules
A project log for Robot Communications Module
Communicate with your robot over long-ranges using a variety of plugins (RF/cellular/laser)
neil-k-sheridanNeil K. Sheridan 04/05/2018 at 19:570 Comments
Following on from the 5.8Ghz log, I'm investigating some of the video transmitters used by drones.
MatekSys  VIDEO TRANSMITTER 5.8G VTX-HV W/ BFCMS CONTROL
You can see details here http://www.mateksys.com/?portfolio=vtx-hv#tab-id-4
TBS UNIFY 5G8 PRO HV
RACEDAYQUADS MACH 2
These are all fairly low-cost (the VTX-HV is around £30), but they are not open-source, so I don't know the components used etc. But I'm sure we can have a look at them anyway! Even if they are not going to be used in the project!
POSSIBLE 5.8Ghz MODULES FOR USAGE IN PROJECT
Anyhow, just looking around, there are some 5.8Ghz TX modules that can be incorporated into our RF plugin for the robot station. We'll be making our own PCB with this and the 433Mhz module on it! We can't just use one of these video transmitters from drones! Because they are not open-source!
FX756T 5.8G 600mW 32CH
So yes, a lot of the 5.8Ghz modules are lower power than this (600mW), so wouldn't be much good for our goal of 1km! This one seems promising!
