Aurora Firmware/Code Updated
A project log for EduCase Portable Classroom
A self contained classroom suite in a portable case for use anywhere in the world regardless of infrastructure
eric-wiiliamEric Wiiliam 09/23/2016 at 23:590 Comments
For those wanting to use the full Arduino control of the Educase I've updated the code on Github. It is now branded as the Aurora firmware for easy identification/tracking. The current build is V1.1
The controller will display our battery voltage levels, monitor temperature, issue alarms, disconnect supply and display all the good info via the trusty 5110 LCD. I'll commit the newer code updates soon!
