Changes since v0.3:
- [NEW] Layout: Added new Datassette pass-through connector PCB. Useful to power the UniJoystiCle board from the datasette port
- [FIX] Client Desktop: Autoresize in Commando and D-Pad mode
- [FIX] Client Desktop: Win client compiled with Qt5.7 so that it works on Win XP
- [NEW] Docs: Added documentation. See DOCUMENTATION.md
- [NEW] ESP8266 Schematic: Reduced real state. Compatible with C128D and SX-64
- [NEW] ESP8266 Schematic: Using D1 Mini instead of NodeMCU to reduce the real state even more. Making it smaller than 5x5cm. Cheaper to produce
- [NEW] Firmware: Added support for Station mode with or without WPS.
- [NEW] Firmware: Added stats: how many joysticks movements are done, and how many seconds are spent in each movement
- [NEW] Firmware: Added mini webserver (http://unijoysticle.local). Use it to view the stats, to set SSID/passwd, to change to Station mode, to change the MDNS name, to set the interval timeout, and more
- [NEW] Client: Added Commando Mode: Control both c64 joysticks with one game controller. Ideal for games like Commando or Turrican 2 were the granedes can be thrown with button B. Buttons B, X and Y are mapped to Joy#1 fire (or space), Joy#1 down and Joy#1 right respectively
- [NEW] Client: Added Commodore Home mode: For home automation. Replaced the old Linear mode
- [NEW] iOS Client: Added Gyruss mode. Allows you to move the joystick with the gravity. Example: allows you to play games like Gyruss using with this new technique
- [NEW] Android Client: new client for android. Supports:
- UniJoystiCle mode
- Dpad mode + controllers: Generic and OUYA game controllers
- Commando mode: Generic and OUYA game controllers
- Commodore Home mode
- Settings
- Resolves unijoyticle.local address
- Can display the server stats from Settings
- Basically it supports all iOS features except Gyruss mode
- [NEW] iOS Client: D-Pad works with MFi and iCade game controllers. When in iCade mode, button A and D act as Fire, and buttons B and C and jump
- [NEW] iOS Client: When using game controllers, optionally jump with button B.
- [NEW] iOS Client: When using game controllers, buttons A and B can be swapped
- [NEW] Tests: New Commodore 64 prg to test the UniJoystiCle + instructions
- [FIX] Android Client / iOS Client: In settings, the default WiFi address is 'unijoysticle.local' (instead of 192.168.4.1). Needed when in Station mode
- [FIX] Android Client / iOS Client: Instead of sending the state 60 times per seconds, it sends twice per state change. Saves battery life!
- [FIX] iOS Client: UniJoystiCle Mode: rotation direction fixed.
- [FIX] iOS Client: Settings: refactored. Looks nicer. Using Navigation Controller + TableView
- [FIX] iOS Client: Launch screen is the same as the first initial screen. Better UX
- [FIX] iOS Client: Settings + Launch screen work both in Portrait and Landscape modes
- [FIX] iOS Client: source code migrated to Swift 3.0 (Xcode 8.1)
- [FIX] iOS Client: Resets Joy state allowing left/right/up/down to be alone
Ricardo Quesada
