UniJoystiCle board v0.2
A project log for UniJoystiCle
The Ultimate Unicycle Simulator
ricardo-quesadaRicardo Quesada 04/30/2016 at 03:240 Comments
I'm about to print some PCBs. I had to change the layout a little bit because the USB cable was interfering with the C64 power cable, and also because it is cheaper to batch PCBs that are < 5cm.
Not sure yet where to print the PCBs though. Any suggestion for a low-volume batch? Seeedstudio Fusion and OSHPark seem to be good candidates.
The latest Eagle files can be found here: https://github.com/ricardoquesada/unijoysticle/tree/master/schematic
