Raspberry Pi Retro Gaming LED Display
20x10 WS2812 LEDs driven by Raspberry Pi/Arduino to play games like Tetris in the living room
I am building a retro gaming display for my living room to play games like Tetris or Snake with a wireless controller while I am sitting on my sofa. 10 columns of WS2812 LED stripes are integrated in a lasercutted MDF frame, which is covered by a transparent wood veneer. The heart of the system is a Raspberry Pi A+ which is integrated in the MDF frame. This Pi is connected to an Arduino driving the LED stripes. Four 8x8 Matrix displays are combined to a highscore display which is also connected to the Pi via SPI.
The wireless controller is based on an ESP8266-IoT-board, which connects to the Pi over Wi-Fi. A Joystick and four Arcade buttons are used for game controlling. The controller is powered by a LiPo and could be charged by a microUSB connector.
Based on the python_games package coming with Raspbian, all games are written in Python.
This project was inspired by Türtris: https://hackaday.io/project/3708-t
Check the videos on Youtube
ledmatrix.pdf
Schematic
Adobe Portable Document Format - 13.96 kB - 06/12/2016 at 14:51
Preview
Download
matrix_cad.zip
CAD files for MDF matrix
Zip Archive - 306.31 kB - 05/04/2016 at 15:44
Download
  • 1 × Raspberry Pi A+
  • 1 × Arduino Pro Mini
  • 200 × WS2812 LED (stripes 30 LED/m)
  • 34 × Lasercutted MDF
  • 1 × Joystick
View all 7 components
  • UART speed issues
    makeTVee01/26/2019 at 05:07 0 comments
    After discussing this issue with several people who want to build their own matrix, I decided to sum up the main points in a project log.
    In the newer versions of the Raspberry Pi with integrated Bluetooth like Pi3B/B+, ZeroW and the new 3A+, the hardware UART is used for the Bluetooth module. The second UART, which is connected to the extension header, is a software UART implementation. This second UART seems to be limited to 250kBaud. You can read more details on this website:
    https://www.raspberrypi.org/documentation/configuration/uart.md
    This project uses 500kBaud for transferring the LED data between Pi and Arduino. I am using an old, non-Bluetooth Pi A+. The only thing, I have changed, was adding this line at the end of the /boot/config.txt :
     init_uart_clock=64000000
    There is an option to change the UART configuration on newer Pis by connecting the hardware UART to the extension header and the software UART to Bluetooth:
    https://blog.adafruit.com/2016/03/07/raspberry-pi-3-uart-speed-workaround/
    I didn't have time to test this, but it looks quite straight forward. Also if there are other solutions, I will update this post.
    Of course, it is also possible to reduce display update timings to reduce the UART speed to 250k.
  • Data visualization (German parliament)
    makeTVee09/29/2018 at 15:25 0 comments
    I just started to play around with parsing data from internet sources to the matrix.
    Starting with this page (German parliament seat distribution):
    https://www.bundeswahlleiter.de/bundestagswahlen/2017/ergebnisse/bund-99.html
    and extracting data and colors from the SVG image using this code:
    doc = minidom.parse('diagramm.svg')  # parseString also exists
        style_string = [path.getAttribute('style') for path in doc.getElementsByTagName('path')]
        label_string = [path.getAttribute('aria-labelledby') for path in doc.getElementsByTagName('path')]
        text_string = [text.getAttribute('id') for text in doc.getElementsByTagName('text')]
        data_string = [text for text in doc.getElementsByTagName('text')]
        rgb=[]
        percentage=[]
        index=0
        for i in range(0,7):
            rgb.append(style_string[i].split("(")[1].split(")")[0].split(","))
        for i in range(0,text_string.__len__()):
            if text_string[i]==label_string[index]:
                percentage.append(int(round(200*int(data_string[i]._get_childNodes()[0]._get_data().split(": ")[1])/709)))
                if index < label_string.__len__()-1:
                    index=index+1
        doc.unlink()
        pix=0
    So after sending this data to the matrix, I got this:
     Nice starting point...
  • Matrix size
    makeTVee04/28/2018 at 13:19 0 comments
    After several questions regarding code adaption for different matrix sizes, python code now has global pixel settings called PIXEL_X and PIXEL_Y.
  • Controller details
    makeTVee03/04/2017 at 07:47 0 comments
    I have uploaded the Arduino sketch of the ESP8266 based controller to Github.
    Wiring is pretty simple, using a Sparkfun Thing and a single cell LiPo.
  • Schematic
    makeTVee06/12/2016 at 14:58 0 comments
      The schematic is now available. There are only three relevant connections:
      1. UART between Pi and Arduino (connected DTR-pin for programming the Arduino firmware from the Pi), with a simple voltage divider for 5V to 3.3V conversion
      2. SPI for the MAX7219 matrix display
      3. Serial connection from Arduino to the WS2812 stripes
  • Android app control
    makeTVee05/26/2016 at 20:40 1 comment
    Instead of the retro controller there is also a small Android app for game control. It provides the same functionality, so no additional controller hardware is needed if you already have an Android device.
    There is a video on Youtube showing the app in action:
  • Github
    makeTVee05/12/2016 at 19:33 0 comments
    Python code and Arduino sketch now on Github. I will add more documentation how to use the code within the next week.
  • Veneer application
    makeTVee05/11/2016 at 19:24 0 comments
    In reply to a comment, I will describe how to apply the veneer paper to the MDF matrix. The veneer I have used, is called Microwood, which is a 0.1 mm veneer with paper backing.
    Before the final full-surface bonding onto the MDF matrix, I did some pre-testing with the glue and the surface preparation of the MDF. To avoid paper curling after the adhesion, I used a solvent based all purpose adhesive (UHU black), which worked as expected. For testing purpose, the black laser cutting edge on the MDF surface was removed with sand paper:
    The following image shows the veneer glued on the MDF sanded off (right) in comparison to the veneer glued on the more or less black MDF. For me, this difference was not enough to polish all the MDF parts and the final result proved me right.
    Because of the paper backing, it is quite easy to apply the veneer and there is no problem with dissolving, although the veneer was rolled up when it arrived.
    If you have any questions, leave a comment.
  • CAD files
    makeTVee05/04/2016 at 15:49 0 comments
    I have now uploaded the DXF files of the MDF matrix. I have used 3mm MDF. The next version will be a combination of MDF and cardboard to save some cost.
  • Weather forecast
    makeTVee04/27/2016 at 19:42 1 comment
    Running Python code on the Pi makes it so easy to realize new features. This is a quick preview of getting a weather forecast on the LED matrix. Using PyOWM to talk to OpenWeaterMap and some 10x10 pixel weather icons, that's it.
    Planned features:
    • animated icons
    • 7 day forecast (slideshow)
    • Barbecue forecast
View all 12 project logs
ourharlequin wrote 02/28/2019 at 08:03 point
Hello again. I already do this. It works on my 16x32 matrix. Thanks for Yours answers. It helps every time. Also i have a questions:))))))
1. How to move clock and icons to the center of the matrix? It's displays clock and icons in the upper corner like if i use 10x20 matrix.
2. How to make a speed of blocks in tetris game faster?
3. How to make a speed of snake in snake game faster?
4. How to make a speed of ball in pong game faster?
5. How to fix a ghost right wall in pong game? The ball is repelled from the invisible wall to the right. It's displays game like if i use 10x32 matrix.
makeTVee wrote 03/16/2019 at 14:39 point
Sorry for the late answer!
1. You have to change the drawNumber calls in the drawClock function. drawNumber gets an offset for x and y as a parameter, so please adapt this clues to your matrix.
2. Please change this values at the beginning of the python code:
MOVESIDEWAYSFREQ = 0.15
MOVEDOWNFREQ = 0.15
FALLING_SPEED = 0.8
3. Change the time.sleep(.15) at the end of runsnakeGame()
4. Change the time.sleep(.1) at the end of runpongGame()
5. Did you changed the PIXEL_X and PIXEL_Y?
ourharlequin wrote 03/18/2019 at 07:35 point
Thanks for Yours answer. I alredy find the option speed of tetris and changed it. I will try fix snake and pong speed. I changed PIXEL_X to 16 and PIXEL_Y to 32 in python and arduino codes. Here is my first public video with Youe project: https://goo.gl/H4hxR6
P.S. I have an idea to make an instruction how i build a changed Yours project for giant matrix and diferent controllers.
makeTVee wrote 03/18/2019 at 19:02 point
I found the bug in pong:
Please search for (ballx<9) and replace it with (ballx<PIXEL_X-1)
Thank you for the video, it looks absolutely fantastic, would be great to see an instruction. If you want you can also join this project on hackaday, I have many ideas how to change the python code for additional pixels.
ourharlequin wrote 03/19/2019 at 07:06 point
Tomorrow I will be in garage and try all! I have idea to port maze generator. Hope, that I can do this;)
andersflex69 wrote 02/27/2019 at 12:36 point
Hi, I hope you have a great day.
I try to use your code on a 22*87 matrix (1914 WS2812B). Everything works as expected as long as I don't exceed 14*20.
Even if I change the buffer size and lower the speed of the UART  nothing appared on the matrix.
Maybe you have an idea for helping me?
Best regards, Anderson69s
makeTVee wrote 02/27/2019 at 16:46 point
Which Arduino do you use? Could be an SRAM issue. You can also try to decrease the update rate in the Python code to decrease UART load.  It is quite a lot of data to transfer!
ourharlequin wrote 01/05/2019 at 09:18 point
Thank You. I will try this! Really want to test yours project on my matrix;) https://www.instagram.com/p/Br7DGNKDfPY/
ourharlequin wrote 01/03/2019 at 21:06 point
Hi. I have a question how to set uart between rpi 3b+ and arduino nano. I already use logic level converter. Maybe I need an extra sketch for arduino or special soft, python module?
makeTVee wrote 01/05/2019 at 07:07 point
As far as I know, Raspberry Pi 3 (and Zero W) are different from the UART compared to all other (non Bluetooth) Pis. Please check this link for more information  https://www.raspberrypi.org/documentation/configuration/uart.md
You also need pythons-serial lib.
Hope that helps.
ourharlequin wrote 01/16/2019 at 15:18 point
Still try to connect pi and arduino by uart:( Maybe You have variant of py file without arduino and uart?
makeTVee wrote 01/26/2019 at 05:08 point
please check my new project log
renatoberrezueta23 wrote 12/03/2018 at 16:25 point
Hello, maybe you have the connection schema of the matrix, i'll be thankful if you can help me with that.
makeTVee wrote 12/04/2018 at 20:56 point
Hello, there is no document right now, but I have started in the lower left corner and then zig-zag connected the stripes ending in lower right corner with the last pixel. Power is distributed to all the stripes from the lower side (you can see it on one of my first project logs).
Patrick wrote 07/10/2018 at 20:13 point
Hello,
is there any preferred supplier for laser cutting of the MDF material? formulor.de is one option, cost approx. 200 euro for one complete set. any suggestion for other suppliers / less costs?
makeTVee wrote 07/22/2018 at 06:27 point
For lower costs, maybe use "Finnpappe" instead of MDF, but it has a different thickness, so you have to change the design. Today I would go to the next fablab to do the laser job.
paulakoden wrote 07/04/2018 at 04:32 point
hello
Really like your project currently making one of my own any chance you could send me apk for the controller
makeTVee wrote 07/22/2018 at 06:30 point
The app currently only works for Android version lower than 7.0. Please send me a PM.
Patrick wrote 06/16/2018 at 07:41 point
Hello all,
very cool project and I just had a look to the software packages required. Obviously the MAX7219 library of the referenced source has changed a lot as it has been developed further on with new features.
Is there a quick fix to use the new library or is everybody using the previous version?
I assume it is all under python3, correct?
Thanks
Regards
Patrick
makeTVee wrote 06/28/2018 at 04:42 point
Thanks! I didn't look at the new lib yet, I will try soon.
Yes, it is all python3
gamer1966 wrote 09/10/2018 at 19:55 point
Without many knowledge in Pythgon, i've changed the code to work with the new libraries. Thanks to Google. You can find my code at: https://github.com/gamer1966/ledmatrix
leelossy wrote 05/10/2018 at 17:11 point
Hello!
Very cool project, we are building the same just with pi zero. Can you please send me the android app?  We will be using this for childrens to try the old games at big display :)
Thanks for the help!
mail: leelossy@rekoteam.hu
Ray Sotkiewicz wrote 03/08/2018 at 23:40 point
Just joined this project. I'm involved in a hack-a-thon event at work and this project is what we're going to use to get familiar with Python.
My problem is that I can't find any of the supporting files to load into the Pi and the Arduino.
Can you point me in the right direction?
Thanks!
makeTVee wrote 03/09/2018 at 04:41 point
Sounds great! For source code check out my Github page https://github.com/makeTVee/ledmatrix
Ray Sotkiewicz wrote 03/14/2018 at 22:28 point
Thanks! It's looking good so far. My LED matrix is 10 columns x 30 rows. (An impressive sight) Just need to figure out how to load the MAX7219  library and I should be off and running.
diego gonzalez wrote 01/25/2018 at 08:57 point
Hello. I have a problem with your project.
Im working on this now, but I cant connect with led matrix.
When I execute games.py and controller sim, I can see tetris on my monitor, but I cant see nothing on my led matrix.
I execute the samples of the library (luma led matrix) and works fine on led matrix, but when I open the games.py with python, the matrix dont work
Can you help me please?
Pd: Can you send me the android app? Thanks for all
my mail : djdiegogonzalez@gmail.com
ymmas wrote 10/02/2017 at 12:42 point
Hey.
I found your project by reading much about led coffee tables. And now i am building my own table and i would like to use your code. Later i hope i can integrate the table to fhem.
My matrix is  24 X 14 and i use ws2812B, a raspberry3 and an arduino nano. I set the baudrate up to 1.000.000.
My problem seems like the same from grim, posted  03.07.17 in his gallery.
You were ready to betray, how do you make the android app?
Sorry for my bad english :)
makeTVee wrote 10/17/2017 at 18:39 point
please send me a pm and I will send you the android app.
zombinary wrote 09/29/2017 at 20:50 point
Very nice Porject, but i have many problems to run the phyton scripts on my rpi zero.
This is my first contact with python an the 'controller_sim.py' returns an 'segment fault'. Also it is not possible to run the 'games_pi.py' script. The library 'socketserver' isn't found and i could not install the module PIL.
I using an pi zero W with '2017-09-07-raspbian-stretch-lite.img'
Has somebody run this script on pi zero?
makeTVee wrote 09/30/2017 at 16:24 point
controller_sim is a simulator to test the code on a PC, so not needed for running the code on a Pi.
Please use python3 for socketserver.
Grim wrote 07/15/2017 at 02:44 point
Hello, it's me again. Good news is that I finished the project in time. Here is a picture if you're interested with how it turned out: http://imgur.com/a/Kg2ey
For some reason I cannot reply to the other comments. However I had a question about the "boot logo" that the teensy displays during the Pi's boot. How did you create that? I am looking to change it however I'm not sure why but when I change the code, I get a crash. Thanks.
makeTVee wrote 07/15/2017 at 06:16 point
That's awesome! Thanks for sharing the image!
For the boot logo i have used GIMP, because it has an option to export c files (.c or .h). Afterwards you can edit the image in a text editor.
Grim wrote 07/15/2017 at 19:25 point
Thanks, eventually I want to have more games and whatnot added. I've been thinking about pacman but haven't figured out how I'd do it. I downloaded gimp and I've exported a picture both to .c and .h however I am not getting the hex values as you did. This is what I get:
Again thanks for the help.
makeTVee wrote 08/07/2017 at 18:13 point
I am back from summer vacation, sorry for the delay. It's been a long time ago, maybe I'm wrong. I tried gimp for sure, but maybe later I used a different tool to convert RGB bin data to Hex string, ending up with tools like Matlab/Octave or something else. If I find the tool again, I'll let you know.
Grim wrote 03/09/2017 at 14:39 point
hey man, really liking your project! I'm currently building a 32x32 Matrix very similar to yours and came across your project after I've already started. I've decided to use your program to run the matrix as a main goal of this was able to play pong, Tetris, and snake. Which yours does! However I'm having some issue with the code. When I play Tetris, the shape will show the entire time going down the board but after it lands, the shape disappears. It only does this for the first 12 or so led rows. Also the clock does not show properly. I've added links to 2 gifs that show the issues I'm having. If you'd be willing to help that'd be great. I'm only using a 16x32 panel right now as I'm working on the build part of the matrix. Your help is greatly appreciated
https://imgur.com/gallery/TNEEA
makeTVee wrote 03/10/2017 at 15:35 point
Did you changed in simulation mode first? I will test it over the weekend and come back to you soon.
Could be a timing issue, because you have 2.5x more LEDs. Are you using the same PI/Arduino setup at 500kbaud?
Grim wrote 03/11/2017 at 00:23 point
What do you mean changed in simulation mode first? If you mean tested, I changed the values however they did not reflect in the simulator. Snake works properly and uses the entire board. It is just the other ones that I am having issues with. I have yet to add the 4 8x8 LED's. Here is a screenshot of my options:
Also, I am currently using an Arduino Mega and RPi3. I was originally intending to use the teensy 3.6 however your provided sketch is not compatible with the teensy 3.6.
makeTVee wrote 03/11/2017 at 15:46 point
Did you changed the pixel values in the drawBoard function (line 1042)?
Grim wrote 03/13/2017 at 18:28 point
good news: somehow got the teensy to work so switched to that and it fixed most my problems. Now I just have to resize the various components. Pong doesn't use the proper borders and I can't find in the code where it specifies the borders. Also I can't change the clock size, I get a crash every time. Not sure if I'm changing them right
makeTVee wrote 03/21/2017 at 19:09 point
Pong does not scale yet, sorry for the code, it was really quick and dirty. For changing the clock size, you have to change the font via the clock_font array. How is your progress?
JM wrote 02/27/2017 at 11:51 point
Hi makeTVee,
this is really great stuff!!!
I´m very interested in your controller.
Can you give me some details on wiring and code?
br
makeTVee wrote 02/28/2017 at 19:56 point
Hi JM
thanks and good point, I will add this information shortly to the log/github
bvanasselt wrote 11/16/2016 at 20:34 point
Hi - Thanks for sharing!  Working on something very similar with my son for a Christmas project.  Any chance of posting any of your code?  Would give us a great starting point for our own project - this is, by a mile, the most ambitious project we've undertaken and we're a bit in over our heads.
Either way, thanks again for sharing!
makeTVee wrote 11/16/2016 at 22:36 point
Sounds great, you will find all the code on Github: https://github.com/makeTVee/ledmatrix
bvanasselt wrote 11/17/2016 at 22:20 point
Thanks!  I see now that you had already posted that link.  I don't know how I missed it.  Sorry about that.  Thanks anyway for the fast reply!
anders wrote 07/11/2016 at 21:07 point
I have been looking for a project like yours for long time!
I'm pretty new to Raspberry Pi. Is there an easy way to connect controller directly without having to change too much code? Instead of wifi.
makeTVee wrote 07/12/2016 at 18:21 point
Sure, you can connect a keyboard or gamepad to the Pi via USB. Then use the event system from the pygame lib which I have used in the controller_sim.py.
Only small changes in the code are necessary, if you tell me your controller type, I will provide you some example code.
Wayne Verish wrote 06/03/2016 at 14:34 point
All these projects are very interesting. So much talent, so many great ideas.
stevemoseley wrote 06/03/2016 at 13:23 point
Any updates coming soon?  Would love to get more detail on this.
makeTVee wrote 06/05/2016 at 10:25 point
Quite busy these days, next updates will be a schematic and some details regarding the MDF frame and a more detailed part list.
stevemoseley wrote 06/06/2016 at 00:04 point
Fantastic.  Looking forward to it.
