Box0 + Node.js = REST Server
A project log for Box0
Free and open source tool for exploring science and electronics anytime anywhere
kuldeep-singh-dhakaKuldeep Singh Dhaka 05/03/2016 at 11:160 Comments
Introduction
Today we will make a REST server using Node.js.
For this tutorial, it is assume that you are familiar Node.js & Express
API
Read Device information
URL: /
Method: GET
Response: {"name":"Box0","manuf":"Mad Resistor","serial":"A2005400E015843503134302"}
Read DIO0 information
URL: /dio/0
Method: GET
Success Response: {"name":"DIO0","count":8,"ref":{"low":"0.000000","high":"3.300000"}}
Read DIO0 pin information
URL: /dio/0/:pin
Method: GET
Success Response: {"pin":0,"name":"0","value":"low","dir":"input","hiz":"enabled"}
Get DIO0 pin value
URL: /dio/0/:pin/value
Method: GET
Success Response: {"pin":0,"value":"low"}
Set DIO0 pin value
URL: /dio/0/:pin/value/:value
Method: GET
Note: :value can be low or high
Success Response: {"pin":0}
Toggle DIO0 pin value
URL: /dio/0/:pin/toggle
Method: GET
Note: Should only be called when pin is in output direction
Get DIO0 pin direction
URL: /dio/0/:pin/dir
Method: GET
Success Response: {"pin":0,"dir":"input"}
Set DIO0 pin direction
URL: /dio/0/:pin/dir/:value
Method: GET
Note: :value can be input or output
Get DIO0 pin High Impedence value
URL: /dio/0/:pin/hiz
Method: GET
Success Response: {"pin":0,"hiz":"enabled"}
Set DIO0 pin High Impedence value
URL: /dio/0/:pin/hiz/:value
Method: GET
Note: :value can be enable or disable
Common Error Response:
Code
"use strict";
var express = require('express')
var box0 = require('box0')
var util = require('util')
var dev = box0.usb.open_supported()
var dio0 = dev.dio()
var app = express()
function invalid_arg(res, msg) {
    res.set('Content-Type', 'text/plain')
    res.status(400).send(msg)
function handle_exception(res, cb) {
    try {
        cb();
    } catch (e) {
        res.status(500).send(e.message)
app.get('/', function (req, res) {
    res.json({
        manuf: dev.manuf,
        serial: dev.serial
app.get('/dio/0', function (req, res) {
    var low = dio0.ref.low.toFixed(6)
    var high = dio0.ref.high.toFixed(6)
    res.json({
        count: dio0.count.value,
        ref: {low, high}
app.param('pin', function(req, res, next, pin) {
    var pin_value = parseInt(pin)
    if (pin_value >= 0 && pin_value < dio0.count.value) {
        req.pin = pin_value
        next()
        return
    invalid_arg(res, util.format(&apos;Invalid pin "%s"&apos;, pin))
app.get(&apos;/dio/0/:pin&apos;, function (req, res) {
    handle_exception(res, function () {
        var pin = req.pin
        var name = (pin < dio0.label.values.length) ?
                dio0.label.values[pin] : &apos;CH&apos; + pin
        var value = dio0.value_get(pin)
        var dir = dio0.dir_get(pin)
        var hiz = dio0.hiz_get(pin)
        value = {true: &apos;high&apos;, false: &apos;low&apos;}[value]
        dir = {true: &apos;output&apos;, false: &apos;input&apos;}[dir]
        hiz = {true: &apos;enabled&apos;, false: &apos;disabled&apos;}[hiz]
        res.json({pin, name, value, dir, hiz})
app.get(&apos;/dio/0/:pin/value&apos;, function (req, res) {
        var pin = req.pin
        res.json({pin, value})
app.get(&apos;/dio/0/:pin/dir&apos;, function (req, res) {
        var pin = req.pin
        res.json({pin, dir})
app.get(&apos;/dio/0/:pin/hiz&apos;, function (req, res) {
        var pin = req.pin
        res.json({pin, hiz})
app.get(&apos;/dio/0/:pin/toggle&apos;, function (req, res) {
        var pin = req.pin
        dio0.value_toggle(pin)
        res.json({pin})
app.get(&apos;/dio/0/:pin/value/:value&apos;, function (req, res) {
    var pin = req.pin
    var value = String(req.params.value).toLowerCase()
    value = {&apos;high&apos;: true, &apos;low&apos;: false}[value]
    if (value === undefined) {
        var msg = util.format(&apos;Invalid value "%s"&apos;, req.params.value)
        return invalid_arg(res, msg)
        dio0.value_set(pin, value)
        res.json({pin})
app.get(&apos;/dio/0/:pin/dir/:value&apos;, function (req, res) {
    var pin = req.pin
    value = {&apos;output&apos;: true, &apos;input&apos;: false}[value]
        dio0.dir_set(pin, value)
        res.json({pin})
app.get(&apos;/dio/0/:pin/hiz/:value&apos;, function (req, res) {
    var pin = req.pin
    value = {&apos;enable&apos;: true, &apos;disable&apos;: false}[value]
        dio0.hiz_set(pin, value)
        res.json({pin})
app.listen(3000, function () {
    console.log(&apos;Listening on port 3000!&apos;)
process.on(&apos;SIGINT&apos;, function() {
    console.log("\nGracefully shutting down from SIGINT (Ctrl+C)")
    dio0.close()
    dev.close()
    process.exit(1)
Interacting
You can use your Internet Browser / telnet to interact with the REST server.
Get device information
Request: GET /
Get DIO0 module information
Request: GET /dio/0
There are 8 pins for this device with low voltage 0V and high voltage 3.3V
You can reference 8 pins via 0, 1, 2, ... 7
Turn On LED on pin number 3
Requests:
  1. GET /dio/0/3/dir/output
  2. GET /dio/0/3/value/high
  3. GET /dio/0/3/hiz/disable
Your led will blink
Reading from pin 4
Requests:
  1. GET /dio/0/4/dir/input
  2. GET /dio/0/4/hiz/disable
  3. GET /dio/0/4/value
Resonse (from 3rd query): {"pin":4,"value":"low"}
This tells that pin 4 is LOW.
Toggle pin 3 value
Requests:
  2. GET /dio/0/3/value/low
  4. GET /dio/0/3/toggle
  5. GET /dio/0/3/toggle
  6. GET /dio/0/3/toggle
and continue toggling it!
