Bode Plot of RC circuit
A project log for Box0
Free and open source tool for exploring science and electronics anytime anywhere
Kuldeep Singh DhakaKuldeep Singh Dhaka 05/26/2016 at 12:310 Comments
Introduction
According to Wikipedia,
A Bode plot /ˈboʊdi/ is a graph of the frequency response of a system. It is usually a combination of a Bode magnitude plot, expressing the magnitude (usually in decibels) of the frequency response, and a Bode phase plot, expressing the phase shift.
Note: The code is not specific to RC, you can actually use it for other type of circuits & systems.
Connection
In the circuit, Capacitor = 0.1μF and Resistance = 550Ω.
Using the formula of Cut-off frequency, f = 1/2πRC
That gives us, f=10.000345=2.89KHz
Code
import box0
import numpy as np
import matplotlib.pyplot as plt
from scipy.optimize import curve_fit
import math
# allocated resources
dev = box0.usb.open_supported()
ain0 = dev.ain(0)
aout0 = dev.aout(0)
# prepare resources
ain0.static_prepare()
ain0.bitsize.current = 12
ain0.chan_seq.current = [0, 1]
aout0.static_prepare()
aout0.bitsize.current = 12
aout0.chan_seq.current = [0]
FREQ = range(100, 5000, 100)
REF_LOW = -3.3
REF_HIGH = 3.3
INPUT_AMPLITUDE = (REF_HIGH - REF_LOW) / 2
data_freq = []
data_phase = []
data_magnitude = []
def set_freq(freq):
    Set frequency to AOUT0.CH0
    :param float freq: Requested frequency
    :return: Actual frequency
    global aout0
    # try to stop aout0 from last run
    try: aout0.static_stop()
    except: pass
    # calculate the actual frequency that can be generated
    count, speed = aout0.static_calc(freq, 12)
    freq = float(speed) / float(count)
    # generate a sine wave
    x = np.linspace(-np.pi, +np.pi, count)
    y = np.sin(x) * INPUT_AMPLITUDE
    # set the configuration to module
    aout0.speed.current = speed
    aout0.static_start(y)
    return freq
def get_best_speed_and_count(freq):
    Find the best sampling frequency at which signal with `freq` can be captured.
    Care is taken to not exceed more than 100ms acquisition duration.
    :param float freq: Frequency of expected signal that need to be captured
    :return: sampling_freq, count
    :rtype: int, int
    sampling_freq = freq * 40 # atleast sample 40 time more than the signal frequency
    max_sample_count = 1000
    max_duration = 0.1 # 100ms
    sample_count = min(max_duration * sampling_freq, max_sample_count)
    # make sample_count multiple of 2, because two channel are being captured
    sample_count = int(sample_count / 2) * 2
    return int(sampling_freq), int(sample_count)
# ref: http://stackoverflow.com/a/26512495/1500988
def curve_fit_sine(t, y, freq):
    """Perform curve fitting of sine data"""
    p0 = (INPUT_AMPLITUDE, 0.0, 0.0)
    p_lo = (0.0, -np.pi, 0.0)
    p_up = (INPUT_AMPLITUDE, np.pi, REF_HIGH)
    def cb(t, amplitude, phase, offset):
        return np.sin(2 * np.pi * t * freq + phase) * amplitude + offset
    fit = curve_fit(cb, t, y, p0=p0, bounds=(p_lo, p_up))
    fit = fit[0]
    return fit[0], math.degrees(fit[1])
def get_data(freq):
    Get channel data of ain0.
    :param float freq: expected Frequency of the signal that need to be captured
    :return: magnitude_in_db, phase_in_degree
    global ain0
    # retrive data
    sampling_freq, sample_count = get_best_speed_and_count(freq)
    ain0.speed.current = sampling_freq
    data = np.empty(sample_count)
    ain0.static_start(data)
    # process the data
    t = np.linspace(0.0, float(sample_count) / sampling_freq, sample_count, endpoint=False)
    input_amplitude, input_phase = curve_fit_sine(t[0::2], data[0::2], freq)
    output_amplitude, output_phase = curve_fit_sine(t[1::2], data[1::2], freq)
    # extract results
    magnitude = 20 * math.log10(output_amplitude / input_amplitude)
    phase = (output_phase - input_phase) % 360
    # convert phase into a value that is around 0
    if phase < -180:
        phase += 360
    elif phase > 180:
        phase -= 360
    return magnitude, phase
for freq in FREQ:
    #print("capturing ", freq)
    # do the main part!
    freq = set_freq(freq)
    magnitude, phase = get_data(freq)
    # store the results
    data_freq.append(freq)
    data_magnitude.append(magnitude)
    data_phase.append(phase)
# free up resources
ain0.close()
aout0.close()
dev.close()
fig, axs = plt.subplots(nrows=1, ncols=2, sharex=True)
fig.suptitle("Bode Plot")
magnitude = axs[0]
magnitude.grid(True)
magnitude.set_xscale('log')
#magnitude.set_yscale('log')
magnitude.set_xlabel("Frequency (Hz)")
magnitude.set_ylabel("Magnitude (dB)")
magnitude.plot(data_freq, data_magnitude, 'r.-')
phase = axs[1]
phase.grid(True)
phase.set_xscale('log')
phase.set_xlabel("Frequency (Hz)")
phase.set_ylabel("Phase (Degree)")
phase.plot(data_freq, data_phase, 'r.-')
# Show the data
plt.show()
Result
