PCB (& 3D) ride!
A project log for Box0
Free and open source tool for exploring science and electronics anytime anywhere
Kuldeep Singh DhakaKuldeep Singh Dhaka 09/21/2016 at 00:550 Comments
3D Top - with components
3D Top - with components (computer generated)
3D Top - without components
3D Top - without components (computer generated)
3D Back - with components (computer generated)
Filled Top
Filled Top
Filled Back
Filled Back
Unfilled Top
Unfilled Top
Unfilled Back
Unfilled Back
You get the KiCad files from git repo here.
2 Layer design, while designing, it was a goose chase to get the right position and connection!
In the charge pump (-5V from +5V) block [and other power management block]:
Special care have been taken to reduce the loop (high current path). by using Via and minimal cut in ground plain.
To make the connector even more stronger, we placed copper under it.
So that the connector can get even more strength from the solder.
