Github Home & Documentation
A project log for DIY Device Cloud
Tools and information to build an internet of things that doesn't suck. Do it yourself!
tdicolatdicola 05/10/2014 at 02:070 Comments
I've started a repository on github that will be the home for all the software output from this project.  Since documentation will be an important part of this project I've also created a base for the documentation at http://diy-device-cloud.readthedocs.org/ using the excellent readthedocs.org service.  The documentation is actually built from files in the github repository for the project (under the docs folder) based on the sphinx tool.  Because the docs are in the repository it's easy to keep them versioned and up to date.  For now I've put up a couple docs that recap what I've covered so far in the project logs here.
