The software is based on the GNU MPFR library (Multiprecision Floating Point with Rounding), using a precision of about 200 digits (665 bits). When displaying such high-precision numbers, you can use a paddle switch to "scroll" the display 20 digits left or right.
robert.c.baruch
John Duffy
hamster
Paul Andrews
Yann Guidon / YGDES
Hey, Can you help to create the similar tool for my DLL project? You I'm already working on it but need little help, you can see here detail https://fix-dll-errors.com/dll_files4.dll.php
