Testing Nixies
A project log for RPN Nixie Calculator
A programmable RPN calculator using way too many Nixie tubes
robertcbaruchrobert.c.baruch 04/27/2016 at 03:220 Comments
So you got a few 50-packs of Nixies from Russia. How do you test them?
With this manual Nixie tester.
It operates from any power supply 7.5 - 16VDC. The button is to test the dot segment.
To build this, you will need:
I would just build this on a perfboard, it's not really worth making a PCB.
WARNING! The output from the NK01A is lethal. That is, it can source an energy of over 13.5 W-sec over three seconds. Be very careful:
