How to open transistor
A project log for Germanium Vision
Low-resolution video camera with a lot of opened germanium transistors used as light-sensitive elements
shaosSHAOS 04/18/2016 at 02:410 Comments
Soviet MP-transistors are relatively easy to open:
First of all you need pliers to hold a head of transistor like this to avoid damaging of semiconductor joints inside:
Then you need to squeeze the head to break it:
If it is not disconnected right away you can help it with screw driver:
After that it will look like this:
Now cover could be easily removed:
