Sun Type S Keyboard Retrofit
Use one of the golden standards of keyboarding on your modern system
This project aims to use a readily-available Teensy-LC microcontroller as a bridge between the Sun Type S serial protocol and USB. Using one of the serial inputs on the LC to communicate with the keyboard, the LC will convert the proprietary (but well documented) serial protocol into common keycodes readable by generic USB HID Keyboard drivers.
Sun Keymap: http://shikasan.net/sunkey/sunkey_e.html
http://kentie.net/article/sunkbd/translate.pdf
http://kentie.net/article/sunkbd/KBD.pdf
Teensy Keylist: https://www.pjrc.com/teensy/td_keyboard.html
Source Code: https://github.com/Oflameo/sun-type-5-keyboard-retrofit
sun2teensy.sch
Schematic for Teensy to Sun serial inverter
sch - 72.30 kB - 05/20/2016 at 05:10
Download
sun2teensy.brd
Board file for Teensy to Sun serial inverter
brd - 37.86 kB - 05/20/2016 at 05:10
Download
  • 1 × Sun Serial Cable Connector
  • 1 × Teensy-LC
  • 2 × 2n2222 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 4 × 1KΩ Resistors
  • 1 × OSHpark designed PCB
  • Boards are in and soldered!
    jareklupinski05/20/2016 at 04:47 0 comments
    The one with the wires soldered directly to the board stays here, meanwhile the other will be sent along to my collaborator. Together we'll finish filling out the keycode map, and tune this to be a light, easy-to-understand, easy-to-mod Sun keyboard platform.
    static byte keyStack[6];
    //TODO handle stack overflow
    byte addToKeyStack( char key ){
      for( int i = 0; i < 6; i++ ){
        if( keyStack[i] == 0 ){
          keyStack[i] = key;
          return 1;
      return 0;
    //TODO handle mismatched character
    byte dropFromKeyStack( char key ){
        if( keyStack[i] == key ){
          keyStack[i] = 0;
          return 1;
      return 0;
    //TODO add keyboard beeper test code
    //TODO add keyboard beeper code to respond to exceptions
    void setup(){
      SerialUSB.begin( 9600 );
      while( !SerialUSB );
      Serial1.begin( 1200 );
    void loop(){
      while( Serial1.available() > 0 ){
        byte in = Serial1.read();
        static byte mod = 0;
        SerialUSB.println( in );
        switch( in ){
          case 76:
            mod |= MODIFIERKEY_CTRL;
            break;
          case 204:
            mod &= ~MODIFIERKEY_CTRL;
            break;
          case 102:
            addToKeyStack( KEY_C );
            break;
          case 230:
            dropFromKeyStack( KEY_C );
            break;
        Keyboard.set_modifier( mod );
        Keyboard.set_key1( keyStack[0] );
        Keyboard.set_key2( keyStack[1] );
        Keyboard.set_key3( keyStack[2] );
        Keyboard.set_key4( keyStack[3] );
        Keyboard.set_key5( keyStack[4] );
        Keyboard.set_key6( keyStack[5] );
        Keyboard.send_now();
  • Schematic and Board Files
    jareklupinski04/25/2016 at 19:23 0 comments
    Decided to just keep it as a Teensy backpack/shield/wing/whatever teensy calls their addon boards. Sending these off to Oshpark, once they come back and I validate them I'll post the Eagle files
  • It lives!
    jareklupinski04/25/2016 at 18:10 0 comments
    Got the keyboard communicating over USB, right now it's spitting out just raw keycodes. Now comes the tedious task of mapping these keycodes to standard USB keys...
View all 3 project logs
AVR wrote 10/01/2016 at 17:44 point
I got an original teensy powering my Apple Extended Keyboard II, hope you succeed in your Sun build, always wanted one of their keyboards :)
