Converting a Mindflex to a MindWaveMobile Headset
A project log for Train Your Brain with NeuroFeedback
Brain hacking!!! Improve your focus and concentration by training your brain using NeuroFeedback.
tom-meehanTom Meehan 10/03/2016 at 02:072 Comments
This basically involves adding a Bluetooth serial transmitter (and configuring it) to the Mindflex Headset and changing some components on the TGAM1 board (the board that acquires the EEG data).
This ended up being a bit of an adventure – even after a good deal of research (reading datasheet's very carefully) and reviewing other peoples tutorials of similar hacks. In the end, it took about a week of part time research on components, Bluetooth (profiles, module boards, communication protocols), TGAM1 board (communication protocols, identifying board connection points, hardware settings etc.). Presently, I have a fully functional headset that is recognized by Neurosky's MindWaveMobile software as a MindWave Mobile Headset.
Hardware: Tools:
Here are a couple of screen shots of the headset working with a couple of applications:
Next up -
  1. Setting up TGAM1 board for raw data communication.
  2. How to Set Up Bluetooth Board to transmit.
  3. Connecting HC-06 Bluetooth board to the TGAM1 Board.
DOBsby wrote 01/14/2024 at 14:25 point
Hey, sorry if this is spammy, but I'm asking these questions far and wide anywhere there might be someone who might know
How similar is the Taurus TGAM to the more popular neurosky TGAM? Does the Neurosky SDK work with it?
Is the Sicihiray Taurus TGAM equivalent to the Neurosky TGAM? I'm looking at getting the Sicihiray but the Neurosky has more online resources. If they're compatible, that's fine. I'm just concerned they're not
jmwilcoxen wrote 12/15/2017 at 17:25 point
I made this but used bluetooth data link for Pixhawk. it's factory setting is 57600, so I connected it to mindflex headset (found. at Goodwill). The data link bluetooth is small enough to fit inside mindflex headset and linked up immediately to my android phone and EEG app.
