I'll explain some simple diode functions using Snap Circuits.
Direct current (DC)
In a DC (direct current) circuit where the electricity flows in one direction, we can think of a battery as a storage tank like the water tower in your neighborhood. If nobody turned on their faucet, the water in the tower would just sit there. Forever. Physicists like to think of this as "potential energy." Like a boulder at the top of a hill, it will just sit there, forever, until someone pushes it over the hill or an earthquake shakes it from the top of the hill or erosion undermines it starting it to roll down the hill. When the boulder is rolling down the hill, physicists like to think of this as kinetic energy. So, the water will just sit in the top of the water tower until you turn on the faucet to your water hose. The water will then flow from the top of the water tower through your water hose and then on to the ground. You can then think of the flow of water as kinetic energy and this kinetic energy can be used to do useful work.
When no circuit is connected to your battery, it is like a storage tank, or potential energy. When a circuit is connected to your battery, you can think of electrons flowing through the circuit as kinetic energy that can be used to do useful work such as light up an incandescent light bulb or light emitting diode (LED).
You can thank Ben Franklin for a bit of confusion that often arises regarding electron flow and current flow. Franklin studied electricity before the discovery of the electron and simply had to guess—and he guessed wrong—so, current flow is backwards. Electrons have negative charges and flow in the opposite direction of current.
Confused? No worries. Just stick with “current flow” (also called “conventional current” or “conventional electricity”) and think of “current” flowing from the positive ("+") terminal on your battery to the negative ("-") terminal, or ground, like the water flowing from the top of the water tower, through your garden hose, and onto the ground.
Alternating current (AC)
Direct current by definition flows in one direction. Alternating Current (AC), on the other hand, periodically changes direction, or reverses polarity. To use a diving analogy, imagine a scuba diver. Since scuba divers carry their air with them they can still breathe whether their heads are above water or underwater. You can imagine a scuba diver surfacing and diving repeatedly and the path he or she traces forms a sine wave.
The sine wave is what Alternating Current looks like. At the crest, or top of the wave you might measure +5 volts and at the trough, or bottom of the wave you might measure -5 volts. At the line through the middle you would measure 0 volts.
It is indeed possible for a portion of a circuit that is normally DC to periodically change direction, or reverse polarity like an AC circuit. Examples can include some 555 timer circuits and circuits that drive DC motors. Some electronic components can be sensitive to reverse polarity and can be damaged by sending electricity through them the wrong way. To protect these components, you can install a diode in the circuit.
According to Wikipedia, “The most common function of a diode is to allow an electric current to pass in one direction (called the diode's forward direction), while blocking current in the opposite direction (the reverse direction). Thus, the diode can be viewed as an electronic version of a check valve." (Source)
What is a check valve? You can think of it like a ping pong ball cage snorkel. When the ping pong ball cage is above the surface of the water, the ping pong ball is at the bottom of the cage and you can breathe through the snorkel. As the cage moves below the surface of the water, the ping pong ball floats up until it blocks the opening of the snorkel blocking any water from getting into the snorkel.
We can use the diode to convert Alternating Current to Direct Current. Now imagine our snorkeler surfacing and diving. While the ping pong ball cage on the snorkel is above the water the snorkeler can take a breath of air. When the cage sinks below the water the ping pong ball blocks the water from getting into the snorkel and the snorkeler has to hold his or her breath until surfacing again to exhale and take another breath. Like the ping pong ball acts as a check valve to prevent water from getting into the snorkel, the diode acts as a check valve to block the voltage from flowing in the reverse direction.
The following is what the voltage will look like when the Alternating Current sine wave is converted to Direct Current:
You would measure from 0 volts to +5 volts then back to 0 volts. You wouldn't be able to measure the voltage reverse direction from 0 volts to -5 volts because it is being blocked by the diode. When the Alternating Current cycles back to 0 volts you would then be able to measure the voltage from 0 volts to +5 volts and then back to 0 volts.
You can build a simple circuit to demonstrate how a diode can block the flow of current.
Parts needed:
1 Base Grid (11” x 7.7”) # 6SC BG
1 Battery Holder (2-AA) # 6SC B1
1 Diode 1N4001 # 6SC D3
1 Slide Switch # 6SC S1
1 6V Lamp Socket (With Bulb) # 6SC L2
4 Conductor with 2-snaps # 6SC 02
Build the circuit shown.
When you switch the circuit on you can think of it as current flowing from the positive side of the battery (marked with a "+" sign) to ground (marked with a "-" sign) and you can think of the flow of current as kinetic energy that can be used to do useful work such as light up an incandescent bulb. So, when you switch the circuit on, why doesn't the light bulb light up? Because the diode is blocking the flow of electricity.
Switch the circuit off and change the diode from the reverse direction to the forward direction.
Switch the circuit on and the light bulb lights up. Now the diode is no longer blocking the flow of electricity and current can flow from the positive (+) terminal on the battery through the circuit to ground (-).
Now let's take a look at the Light Emitting Diode (LED). The light emitting diode functions much the same as an ordinary diode, but also lights up when enough current is flowing through it in the forward direction (forward-biased). LEDs are often used in electronic devices to indicate that the device is switched on, but they can serve many practical purposes.
Parts needed:
1 Red LED # 6SC D1
When you switch the circuit on...nothing happens. Why doesn't the light LED light up? Because the LED is reversed and blocking the flow of electricity.
Switch the circuit off and turn the LED around.
Now you can switch the circuit on and with the LED in the forward-biased direction, it lights up.
The diode has a number of applications in electronic circuits. One application you may be familiar with is a rectifier. A rectifier converts alternating current (AC) to direct current (DC). Alternating current periodically changes direction while direct current only flows in one direction. "The most common function of a diode," according to Wikipedia, "is to allow an electric current to pass in one direction (called the diode's forward direction), while blocking current in the opposite direction (the reverse direction)." Using Snap Circuits, I've shown it’s easy to demonstrate how the diode will let current flow in one direction but block the flow of current in the opposite direction.
Follow me on Twitter: @SteveSchuler20 and right here on Hackaday: KRA5H.
Pleas follow this project and "Like" (formerly know as "skull") this project.
Teaching programming and Electronics with Snap Circuits and the Kano Computer NEXT ARTICLE
Teaching programming and Electronics with Snap Circuits and the Kano Computer PREVIOUS ARTICLE
