TestNeoPixel3.inoThe arduino file to run the Neopixel Ring on the trinket.Its programmed to do one circulation of the LED ring in 6 seconds. During the first minute, 4 leds are red. In the second minute, 8 leds are yellow and after 3minutes are reached, it blinks green. Simply to indicate, that the recommend 180 sec brushing time is reached. x-arduino - 2.35 kB - 04/19/2016 at 20:45 |
toothStand4.FCStdFreeCAD file of the inner base.The colored parts should simulate the parts (usb charger, trinket, battery, motor) x-extension-fcstd - 26.48 kB - 04/19/2016 at 20:15 |
connector.fcstdFreeCAD file of the part which is mounted on the motor shaft and connects the motor with the tooth brush headx-extension-fcstd - 27.44 kB - 04/19/2016 at 20:15 |
tube.stl3D printer ready file of the outer tube/housingStandard Tesselated Geometry - 152.23 kB - 04/19/2016 at 20:15 |
deckel.stl3D printer ready file of the top part which covers the inner parts and holds the pipe (aka the storage for the tooth brush head (if it would fit ;)))Standard Tesselated Geometry - 62.09 kB - 04/19/2016 at 20:15 |
pipe.stl3D printer ready file of the pipe aka the storage compartment for the tooth brushStandard Tesselated Geometry - 56.33 kB - 04/19/2016 at 20:15 |
connector.stl3D printer ready file of the connector between motor and brushStandard Tesselated Geometry - 31.33 kB - 04/19/2016 at 20:15 |
