Divided Solderless Breadboard
Divide a traditional solderless breadboard down the middle with a hacksaw.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A solderless breadboard – as traditionally designed – has, in some circumstances, become less than ideal. Again, in some circumstances, it has even become impossible to use. As electrical devices have become wider and wider they have become less able to be fitted into the fixed width of the standard solderless breadboard.
One fix for that problem is simple: divide the breadboard down the middle of the long axis of the board allowing the now split sides to be spread apart as widely as needed to accomodate any electrical device desired – with plenty of breadboard pins exposed on either side of the device.
yey!
http://www.instructables.com/id/Divided-Solderless-Breadboard/
