A relay constructed from materials found in the home and will hold up to actual daily use.
Got rid of the weights and trying out a simple rubber band. So far it is working very nicely and my wife gets her fishing weights back :-)
This the first test run for the relay.
This is with the contact gap adjustment screw added and the relay connected between IO and the typewriter/printer for a slow test.
