4-bit TTL ALU
A project log for One Transistor FlipFlop
Flip-Flop design with just one transistor. Nice for transistor-CPU's ! The principle can also be used for vacuum tube flipflops.
roelhroelh • 08/15/2018 at 20:46•0 Comments
If you are interested in flipflops, building CPU's might also be of interest to you.... I started a new project, a 4 bit TTL ALU with only 7 TTL IC's.  It fits on a 1 x 1 inch PCB.....
And the next project is a TTL CPU on one square inch !
