More extensions
A project log for MO5 interface boards
I'm a Thomson MO5 fanatic and despite its bad rep, it's a very nice machine that is easy to extend.
yann-guidon-ygdesYann Guidon / YGDES 04/07/2018 at 01:030 Comments
How do you solve an extension problem ? Get more extensions ! I found a couple more Nanoréseau adapters on classifieds:
It's interesting to know that the Nanoréseau required quite a lot of RAM so each adapter comes with a memory extension (64KB). I have already seen this extension in a MO5 computer as a "hack", where the cartridge port was removed to integrate the 64KB PCB inside the box. One can see the 4164 DRAM chips, 2 of them are enough to create a 64KB block.
This is very interesting indeed.
One important aspect of this project is to create new extensions. Now I can measure the physical dimensions (bring the caliper !) to make compatible cartriges as well.
I already had small ROM cartridges and I can compare with them.
(pictures here)
I also found a "game port extension" that contains a 6821 that drives a 6-bits R/2R DAC and a couple of switch-based joysticks. Note that the board contains no address decoder, isn't it interesting ? :-)
By cutting the middle connexion, we can get the 6821's ports and hook 16 bits (?) of bidirectional IOs, which could be enough for simple robotics and/or model train control...
So overall, most of the MO5's extensions are easy to modify and repurpose. It's not only a great platform to learn about programming, but also to learn about hacking :-)
