20160427_184226.jpgIR Transmitter moduleJPEG Image - 2.06 MB - 04/28/2016 at 06:49 |
20160427_184453.jpgIR Reader ModuleJPEG Image - 2.12 MB - 04/28/2016 at 06:49 |
20160427_184133.jpgReceiver Module- Kept in front of device to be controlled - RF module receives the IR code - The controller board decode the code - Emits IR signal JPEG Image - 2.28 MB - 04/28/2016 at 06:43 |
20160427_184727.jpgTransmitter Module- Connected to Mobile - IR reader detects the IR signal - The controller encode & saves the IR code - RF module transmits the IR code JPEG Image - 2.37 MB - 04/27/2016 at 13:43 |
20160427_184255.jpgRF Module- Works on 2.4GHz - RF Transceiver JPEG Image - 2.16 MB - 04/27/2016 at 13:41 |
20160427_184313.jpgMicro Controller BoardJPEG Image - 2.36 MB - 04/27/2016 at 13:41 |
