Mechaduino 0.1
A project log for Mechaduino
Mechaduino is an affordable, open-source, industrial servo motor. Position, torque, velocity, and custom modes. Arduino compatible.
jcchurchjcchurch 05/24/2016 at 07:450 Comments
New prototypes just arrived!
This version features hardwired connections to the motor driver and encoder (no more jumpers!), fewer through-hole components (only connectors), 5V compatible level shifters on D0 and D1, and a more thoughtful board layout. The new boards are slightly smaller, and do not overhang the edge of a NEMA 17 motor. We also arranged our power connections so that a 3 terminal 5V regulator (the classic 7805 or a modern switching equivalent), could be installed for single supply operation.
All the latest design files are on github!
Here's a photo of the older prototype boards (Mechaduino 0.0) wired up to a few different stepper motors including a NEMA 23:
