3D models
A project log for A new high accuracy tilt sensor
This project aims to build a tilt sensor that is cheap, very accurate and has a wide measuring range (up to 360 degrees).
aron-molnarAron Molnar 09/24/2016 at 16:100 Comments
We made some 3D models about the sensors and the resolution measurement test bench just to visualize them better. Here they are:
Linear FCDT:
Toroid FCDT:
Resolution measurement test bench:
